F firthy Aug 15, 2020 #1 Hi, Help ive just replaced an ignition barrel on my micra it has 2 new keys it will not start even with the original keys with the chip next to it, when trying to start the engine management light is on Last edited: Aug 16, 2020
.Maarten Aug 16, 2020 #2 Is the engine light solid on or flashing? And did you replace the ring around the barrel?
.Maarten Aug 16, 2020 #4 That’s a nats error. are the new keys programmed to the ecu? If not do they have a chip? If so swap the old chip into a new key. If nats detects a wrong chip Or no chip it will flash the check engine light.
OP OP F firthy Aug 17, 2020 #5 Thanks Maarten no the new keys do not have a chip i just put the old key with the chip in next to the barrel hoping that it detects the chip.
