Daughter has a K12 wit the key less entry, some times she struggles to turn the ignition, you have to press the brake and jiggle the steering wheel quite a big amount is this normal?
Can it be maid easier?
The K12 Micra is a bulletproof car. It's great... but has 3 issues. Defective key fob, stupid radio and horrible headlights (later corrected).
I own 2 K12's. one '04 and one '07. The '04 has a keyless start and not only is it difficult to start (just in the way you described) it has wrecked two ignition barrels... Luckily the 07 version doesn't have a keyless start and is much better. You cant really do anything I'm afraid, but next time you buy a K12 avoid the keyless start!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
