Idle control Valve (prefacelift)
Hi All
My cold start idle is getting a bit worse, lumpy running and sometimes fluctuating revs and a cut out, when it's warm much better, but get an occasional low idle and cut out.
I want to take out and clean the ICV, is the procedure, air filter housing off, 2 screws (hopefully they come out ok), then clean it with brake cleaner, is that correct?
