high pitch noise
B
Bennai
i have a funny high pitch noise that comes from my tweeters
and it sorta goes with the revs of the engine,
like the more revs i give the car, the higher pitch this noise gets, then makes a funny noise when u change gear and starts agen. but when i turn the hedunit off it all stops!!
any ideas?
Arnold
www.alanarnold.co.uk
Moderator
Check the earths, also make sure your alternator has a supressor attached to it!
NeX
You're after my robot bee
i've had this, what you need is a ground loop isolator, buy one from maplins £12 i think...
i'm assuming your system is amped?
Yes you can do this but doesn't always work, the whine can also be caused by badly installed rca's and power leads, if you are running amps of course. Just ensure that speaker wire/rca's are run through car away from the power leads.
Other than this the whine can also be casued by faulty rca ports on your headunit...
NeX
good point, i ran the power down the sides and all the data cables down the middle :)
basically every part between the source (HU) and the amp need to be shielded from interfernce...
OP
OP
B
Bennai
my rcas, go on the right and power on the left
il trry a ground loop isolator form ,maplins wen i get paid!
OP
OP
B
Bennai
do you need one for every set of rcas running into your amp
