High Idle (1100 rpm) Pre-facelift
Hi
One of my K11's is idling slightly high around 1100rpm when warm, 1400rpm when cold then drops down to 1100rpm, it doesn't hunt just stays at that, it's not a massive issue, but prefer to slightly lower it, if there is a way.
I've cleaned out the TB & ICV, but hasn't made a difference.
Check the waxstat. And adjust the idle with the idle screw (hex) on the back of the throttlebody. Dont forget to unplug the tps and rev the engine a few times before setting the idle.
Ok thanks, which one is the TPS, (is it the plug in the photo), along with the hex screw.
