Help with cg13
Fitted a cg13 to my k11 a couple of months ago
Ever since fitted it has a misfire through the rev range.
Also on start up it 'hunts' on idle for a few seconds
Just recently replaced the timing chain as it was a bit loose
Also changed the distributer to see if it helped but no joy
Any ideas or anyone else had this problem?
Any airleaks or loose vacuum hoses?
Properly put in all the plugs?
Set the timing to the correct value using a strobe?
Is the MAF still good?
A video might help most of the times unless any of the more able guys on here have a better idea.
