HELP! QUICK! adjustable panhard rod
ferritboy
Just about to fit an adjustable panhard rod- the car has been lowered 50mm and we need to know how shorter the panhard rod need to be compared to the standard one?? Is it 50mm or 25mm?? Thanks in advance - Ferrit.
Matt told me it would be about right 1inch shorter than stock. I'm no authority on the subject but I too have 50 lower and still a stock pan rod so I've got the same job to do. Hope this helps....
drop the car so it sits on the springs alone then it should sit straight and adjust the bar till it fits, thats what i did
We have given it ago and there is now way 25mm can be adjusted, we only just managed 5mm!!!! The only way 25mm can be acheived is by porter powering the wheels together.
