Help identify brakes please.
Anyone got any ideas what these are off. Should be Nissan.
There is only a carrier, no extra bracket.
taking the pads int a motor factor on Monday, they reck they can identify them and back track to a calliper.
Front carriers with rear k11 rear calipers
Doesn't surprise me they fit since alot of nissans can be swapped ,
Ran primera calipers on d21 carriers and discs tight but worked decent
Sent from my moto g(6) using Micra Sports Club mobile app
whats the D21 carrier’s off? Was this for a rear setup?
Wouldn't fit ,
Just saying for reference on how nissan parts can be like Lego,
D21 brakes small are twice the size of micras ones and 6x139 lol
Mean you will need to check the specks but Almera rear brakes?, Since those are bigger some vented (apparently) ect
But that's of you want that tbh,
Other wise what you have is a check and easy enough setup to maintain
Wouldn't fit ,
looking at upgrade as these are not working as a main brake. Will try new pads as the old ones may be hard and glazed.
the discs are good so trying to keep it as standard as possible but may need to rethink it.
the reason I joined the site was for the wealth of knowledge about the car.
Grind the pads back ,
Otherwise look up Almera brakes tho check the rear caliper fitment ,
Fronts are getting harder to find rear no one really wants and plenty of parts lol,
And tbh the setup it's a small piston working so can see them been weaker then stock
