Hello, member from Coventry
#1
Hey all, I'm a long term member over on Almera owners club. Thought I would sign up, say hello and check out some of your builds. Hopefully there is someone on here done a throttle body project I can gain some ideas from as that is my next stage in engine tuning.
#8
The ECU is from a GTiR running nistune board. On this particular build i have used a B14 sentra GA16DE dizzy as the trigger wheel has the 360 slots where the UK GA uses four long slots on the trigger wheel.
Once I sort a sellers fee I will make a dedicated thread for this engine.
Put it this way it is faster than the SR20 im using currently.
frank
#9
that setup should fit a CG too eh, the stock GA uk dizzy has the 4 + 1 slots like the CG iirc, and the 360 slot setup is easier to tune apparently
