hello everybody
Status
Not open for further replies.
had a loan of a k11 for the last 6 months, been great so far, but just snapped its first clutch cable 5 minutes ago, stuck on a double yellow o_O
is it quite an easy fix ? i'm used to working on mini's so should manage it myself, but is there much involved ? don't have a haynes yet looking for an online version.
any advice well appreciated
cheers
snapper (of clutch cable)
jim_bling
welcome to the wonderful world that is micra enjoy your stay
haha to ya user name i cant see it being that hard mate but i havnt had to replace one yet
im sure some one will be along soon to tell you
frank
hi snapper (Y), yeh they,re a doddle, 10mm open end and a torch (to see where to hook it on the pedal)
OP
OP
S
cheers for the warm welcome guys : )
just had a quick lesson in how to drive without a clutch and got parked up for the night somewhere where the traffic wardens don't lurk (not easy).
found a cable on ebay http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=130242753515 does that look about right ? reckon anywhere local (edinburgh) might have one ? are nissan dealership usually a rip off ?
took a bunch of pics to try and see where the cable goes, might post a few to see if anyone can explain, sounds easy enough though... get a 10mm spanner, drill and remove all the screws for the dash.
Just wondering how to get to the other end of the cable, ie the clutch end... underneath crawling about i guess. best place to jack up the micra ? might get a haynes out the library tomorrow.
many thanks
snapper
GuyH08
many thanks
snapper
How did you drive without a clutch fwn lol
OP
OP
S
heh, i meant to say "drive without a clutch *control*"
bump start it in 1st, blip the throttle and when the revs start to fall, slip it into second, basically blip it, wait 1/2 sec or less and get it into neutral or the next gear, just have to match the revs to the gear... wouldn't recommend it on a busy road!
frank
many thanks
snapper
that cable looks ok to me, and just shine a torch at the top of the pedal and you,ll see where to hook it on, then hook the other end on the arm (below the battery) and adjust to suit :)
OP
OP
S
ah, so that's where it goes (Y)
just cycled 8 miles to pick up my new cable from unipart bloody knackered :sleepy:
is it worth removing the dash/centre console to get in to the pedal first ?
cheers
Antony
i do that all the time, using my quick shifter and rev matching the gearbox. saves some time but im sure its wearing something out..lol
OP
OP
S
fixed it!
what a dirty swine of a job, gave myself a headrush from lying on my head under the pedals.
top tip: use your right hand to hook it on the pedal, awkwardly tried with my left hand for 2 hours, was about to give up when i tried with my right (it's a really tight squeeze) but got it within 2 minutes!
...then it started to #### down so left reassembly till tomorrow.
bloody cable was intact, it was the stupid *bakalite* WTF! end clip that had broken off!
you reckon they design them that way on purpose ?
a) they break before the clutch goes ?
b) to save money on a metal end clip (stingy b*st*rds)
c) to line up work for nissan dealerships ?
Status
