Heater Delete
Hi folks,
Removing & bypassing the heather matrix.
Are there any pros or cons to either looping the hoses back into each other inside the bulkhead vs joining the pipes that run from the block itself?
Enuo
Glorified Electrician
I've deleted the heater on my swap. Demister is a LOT less effective withoit heat. Had to fit wind deflectors so I can have the windows open in the rain to demist...
Cheers Andy for the use mine gets il be coating the windscreen with the anti fog stuff the rally / bike guys use.
Two little 12v PC style fans to get some air into the cabin I think
Enuo
Well think of all the coolant weight as well as hose weight you are saving :)
Use em for those lost brake bleed nipple caps too ;)
Enuo
As long as top of the rad bypass loop is below the top of top rad hose you should be fine, otgerwise you can get an airlock.
