Heater blower motor speed control
R
rosey
Hi All,
I have a 1993 micra with a problem. The heater motor only works on full setting (number 4) and there is nothing on settings 1,2 or3.
Can anyone tell me where the heater motor resistor pack is located so i can remove it and replace it with a working model.
How easy are the to fit on these models ???
Rosey
mean micra
www.mightymicra.co.uk
have just changed one in my mates sunny, common fault...
> look under glovebox
> see black cylinder(tis motor)
> to the right of this a brown clip, four wires runnig off it
> the card is behind this
> remove the brown clip
> pull card out, like size of credit card with a funny pattern.
> replace this part with another from scrappers.
all in all 10min job max...
steve.moody
Buy & Sell Member
edit- Wooops i'm a bit slow at replying :D oh well i'll leave what i wrote anyway
It is very easy to replace the resistor,
Under the glovebox section of the dash you'll find a cylinder thing which is the motor for the fan and also a connector.
The connector which is brown has a card attached to it. You take it out by undoing the two screws which hold it in place.
You need to replace the resistor card connected to the brown plug and put it back in and it should work on all 4 speeds.
Here is a picture showing the location of the resistor card
http://img.photobucket.com/albums/v4...y/P1010003.jpg
The thingy with the white squiggle on is the motor for the blower.
