HeadLight Problem
Zephyr
just wondering if any 1 else encounters this with the k11 micra headlights but the plastic block thing that holds the wires n connects to the bulb melts? then that = dodgy light i do know that i aint the only 1 that encountered this with the k11 micra
when i got my k11 the full beam light didn't work on one side. i put it down to damaged bulb, but on closer inspection i found the wires were melted. although they were just connnected straight to the light without the proper plug so i just put it down to this
THIS is suck a common problem...
Ive had 3 k11s and they have ALL had this problem..
I assume you are refering the the 15amp ( blue ) fuse thatsin the fuse box infront of the battery..
its for the Off side or left side of the cars main headlight..
best thing is to take it apart and wire the wire yourself directly .. through a seperate fuse holder..
Very small job..
kristian..
if needed i can post pics of what i did to mine..
