Headlight 3 pin connector
Might be height adjustment motor? If your vehicle is equipped with that option? :rolleyes:
Just for curiosity, you wrote this to Block-section?? :unsure:
John_D
Radio Code Guru
As Mika said above, you have posted this in the wrong part of the forum.......
However the plug, which Mika correctly identifies as the headlight levelling motor control plug should have a metal flat topped 'U' shaped wire clip running across the top, which has to be pushed down to lock the plug in place after it has been connected to the headlight....
