Head porting
Hi has anybody ever tried porting and polishing there own cylinder head, ifso what have you used and what special tools are needed. I know this can be trickey so was thinking just to do a mild port to remove the rough casting marks. Will be greatful for any help
matt
there,s a how-to thread with pics in the k11 guides matt (members only tho)
and this tool makes short work of porting, a rollpin welded onto a hex rod, where you slide the end of the emery down the slit and wrap it round to make a sanding drum, that you can increase or reduce the size or taper it
I followed that guide Frank's talking about, I went a bit further than just casting marks though.
These were my tools of choice, the carbide burrs were excellent at removing material.
How far have you gone. Have you got any pictures, thanks for the replies.
matt
There's some info of where to remove material from in the guide, I used a few other sources too. I've got a few pictures in progress, but not of the finished piece, need to borrow a camera.
