Head porting
Hi has anybody ever tried porting and polishing there own cylinder head, ifso what have you used and what special tools are needed. I know this can be trickey so was thinking just to do a mild port to remove the rough casting marks. Will be greatful for any help
matt
frank
there,s a how-to thread with pics in the k11 guides matt (members only tho)
and this tool makes short work of porting, a rollpin welded onto a hex rod, where you slide the end of the emery down the slit and wrap it round to make a sanding drum, that you can increase or reduce the size or taper it
euro_micra
Matt :)
I followed that guide Frank's talking about, I went a bit further than just casting marks though.
These were my tools of choice, the carbide burrs were excellent at removing material.
euro_micra
Matt :)
How far have you gone. Have you got any pictures, thanks for the replies.
matt
There's some info of where to remove material from in the guide, I used a few other sources too. I've got a few pictures in progress, but not of the finished piece, need to borrow a camera.
