having trouble with my car , acceleration
do you think i should just run it as it is and wait for it to breakdown , i only drive locally at the moment as im afraid a long distance she wont make it
u be wasting more money rather it breaking down , do some checks, clean all the bits u need to like Thottle, idle valve, fuel pump, fuel injectors , sparks, dizzy. , maybe it will help
i feels like a limp mode yer , just revving it in neutral wont give me full rev range . check engine light doesnt come on though
Id be inclined to look into that tps sensor? If the engine doesn't know the throttles open then it won't inject the fuel.
Or like Guy suggested one blocked injector or collapsed cat can have negative effects.
Have you tested the exhaust or injectors? Quite simple :)
