Other plans mean that these are now up for grabs. Wheels only 4x 7x13 Wolfrace slot mags. £120.
2x 7x13 et5 4x100 / 4x108 These are double drilled, with cover plates hiding the unused holes.
1x 7x13 et5 4x4" (4x101.6) This wheel is used on the narrow side of the car after the panhard rod has shifted on lowereing. (or with a 10mm spacer - supplied if wanted)
1x 7x13 et -7 4x4" (4x101.6) This wheel is used on the wide side of the car after the panhard rod has shifted on lowering.
4x4" PCD wheels will be supplied with shift washers and aluminium spigot rings, use flat faced nuts (your stock wheel nuts turned over)
4x100 PCD wheels will be supplied with 60 degree taper wheel nuts to suit
Also included is
1x Wolfrace Slotmag 6x13 et13 4x100/4x110 to use a spare.
No tyres are included and will be removed before collection/delivery. I can arrange for delivery at buyers cost.
Also included is
