goin for a new engine
fraz_micra_88
will be getting a 1.6 conversion when i am back from new york :)
so it will come out of an almera so i will need
new engine mounts, drive shaft, ecu and wireing loom....that correct?
Gurpreet
Engine complete with back plate, flywheel, inlet manifold with injectors and clutch assembly... we'll id change clutch..
Might be worth getting the starter motor too.
Throttle body?
Arnold
www.alanarnold.co.uk
Moderator
Site Supporter
You might aswell get the 1.6 over the 1.4 considering the effort's involved.. then again, you might aswell get the 2.0! then stick a turbo on etc :p
djlee_dj
complete engine , gearbox, engine wiring loom and driveshafts.
the driveshafts will need shortened micra/primera hybrid, as well as loom. gearlinkage needs lengthened or shortened cant remember atm. chassis leg needs modified. mounts need work.
also be best with larger bore echaust from manifold back, but make it you can swap cat/decat for mot time.
