Gearbox
frank
there are some recent ratio threads mauchie, and you would need to redrill a flywheel to fit a 1.3 g/box (5 bolt/6 bolt crank)
frank
it should be an RS5F41 then, a prefacelift 1.0 k11 diff should fit, but the crownwheel pinion and output shaft are 1 piece tho (so you would probably need the whole gear cluster)
Enuo
Glorified Electrician
Would the ratios even be different? Would have thought that if anything the 1.2 diff would be taller
OP
OP
M
Yupp agree with that frank am looking for ither 3.81 or 4.05 any ideas what they come out of the box ave got is a 5speed so a guess thats the 3.81?
Enuo
So WAY taller then, probably because they were designed with 12" wheels in mind that need to spin faster for the same forward motion than the k11's decadent 13" wheels :)
Enuo
RS5F41A
1st: 3.412
2nd: 1.958
3rd: 1.258
4th: 0.921
5th: 0.721
Final: 3.591
As all 1.2 K10's have.
Hi I am looking for a taller 2nd gear for oval racing I have a 1.0 K10 with 4 speed
can anyone held either with a info on a better box or diff that will work
