hey guys first post i recently purchased a 1.0 k11 purely for commuting to work
it badly needed a service and i just carried it out. just the usual, check everything over and new plugs new oil and oil filter and air filter
car is in very good condition for its age. 25k and its a 96 model
seeing as its over 10 years old i also wanted to do the gearbox oil
armed with the trusty haynes manual i had a quick go but got stuck:wasntme:
cos its pre 98 apparently you have to remove the speedometerdrive, haynes manual states that the speedometer cable knurled retaining ring needs to be removed first before the speedometer drive can be removed
thing is haynes states " unscrew the knurled retaining ring. i tried with my hand and could not do it. i did not have a suitable sized spanner so could not try the spanner. do you have to use a spanner to losen it?? seems like stupid question but the manual is written in such a way it should be easy. if you need a spanner what size is it??
i did try and just removed the 10 mm nuts that secured the speedometer drive but it appeared stuck in the gearbox still:wasntme:
