Probly kick myself when I fi d out how but im fine doing the selector rod and putting the support to the gaiter but where the heck does that metal block with the m10( I think stud) go?
Think ive figured it out, only way I can see it being is if the bolt has snapped when I took it off and that it should have gone through the link and the middle of the rubber of the engine mount doubling as the bolt for the engine mount. Ill take a pic when I go back out.
Pic of the block, just gave it a wire bush on end and dont look snapped but got it in my head that im gonna weld a bolt with the head cut off on tommorow
Issue sorted. Found the bolt that goes through the rear engine mount and the support and the block goes on the other end through the rubber behind the gearstick.
Knew id kick myself when I got it
