I wanted to get a better look at the ball joint as shifting felt a bit notchy and dry, took the 4 torx screws out hoping to lift that plastic assembly off but I realised it's clipped in from underneath. The shifter assembly has dropped down and I can't get the screw mountings to meet up properly from above; do those 4 hex bolts and 2 plastic clips hold that plastic mounting in place?
If so, am I better attacking this from underneath? Just thought I'd ask as I'm on my way to pickup a trolley jack and some decent axle stands. Next time I'll just spray some silicone instead.
