GE16DE gearbox and driveshafts?
I plan to fit a GE16DE in my 86 K10 this winter, and would like to know what geardbox and driveshafts i should use.
nexussteve
The reason you're happy!
I'm currently working on this conversion. I'm using a K11 1.3 gearbox and shafts on the GA16.
Money-willing, she should be running soon, so I'll let you know how it goes :)
frank
What yearmodel is the preface k11? how much power would you think that combo would withstand?
The pre 98 1.0 has the same size and shape gearbox and shafts as the k10, and mine has stood 130 hp and 123 lbft so far :)
You will need to fit the flywheel and a hybrid 1.0/1.3 clutch for that tho
OP
OP
Will3
Yeah ive read that the GA is iron block, so either CG10 or CG13 would be better for handling, carbs is not an option tho, i hate carbs, fuel injection controled by Megasquirt is the way i want to go.
Are the CG10 and CG13 same block with different bore? or is it stroked to give more cc?
OP
OP
Will3
The K11 i saw at the junkyard today was injected.
EDIT: It was a CG10
The megasquirt would fit under the glove compartment, where to there ar two big cable rubber holes, and my car is lefthand drive.
nexussteve
I've heard the GA16 can take over 300BHP with stock internals.
It also takes Vitara Pistons as an upgrade. (But I really don't know much about this)
