ga16 throttle bodies and injectors
Is it a direct fit to a cg engine? If so I'll take it.
Edit: iirc you need a plate or something ....
you dont need a plate mate all you need is to make a cover that basically covers where the aav is on the throttle which one of the throttle bodies already has (Y)
I read in a few posts that you get ruff idle? And a few wires need swapping? Can someone confirm.
Is it possible for you to remove the aav and cover it up for me? And if it's a direct fit I'll take it
i just needed a standard tb but if this works out better (and cheaper (Y) )
i think it depends on year etc, mine went streight on using same plugs and wires etc only alteration was blanking plate for aav. my car is a 96 p-reg vibe
forgot to mention, there is a slight rough idle but once the throttle is used there is no holding back and there is no other probs etc but thats my micra others maybe different.
pm me if interested and we'll arrange paypal
injectors sold thanks harlen(Y)
