Enuo
Glorified Electrician
Hi everyone, I did a bit of research on this and I found a few threads alluding that the 190mm GA16 friction plate fits with chamfering, but the GA14 clutch cover doesn't fit over the 190mm friction plate so the GA16 one has to be used (new pcd drilling). Does anyone know if there is clearance or if the GA16 cover plates needs any mods to fit? I got a GA16 clutch sitting here and a clutch that needs changing
