front springs
Hi Guys, does anyone know if there are any standard height stiffer front springs available as the standard ones are a bit soft.
Fujiwara-Ben
Site Supporter
Hmmm only thing i could think of is using K11 Micra 30mm front lowering springs, they are up rated and being that the K11 is slightly heaver than Pao's it should work out so you get pretty much standard ride height and less rolling around corners, could also go for K11 front shocks as they are also a bit stiffer and are a bolt on swap :)
