i run with about 1mm of slot, 2mm is a lot for a daily driver (probably about 4 deg )I meant one size smaller than stock so i guess M10 how much degrees would a 2mm slot give?
I know for some people, modifying standard parts is cheaper than buying aftermarket - but don't Eibach make camber spacers?
Yeah, I can understand wanting to do things cheaper in these current times. Pics of results?
cheap and/but very safe/secure
its on the "project charlie" blog ?
Is it? The corsa coilies came pre slotted all me and frank done was widen it a little off center got possibly 2degrees camber max
Thank you all for your advice. I just found out that there will be no more track days for me this year so im not in a hurry to do this. Might save up for camber bolts over the winter
