Hi all,
New micra owner (2000reg 1.0 16v) and hoping you guys can help me out with a couple of queries.
Firstly, it has a rattle from the front offside and further investigation reveals that one of the bolts into the slider bolt has been threaded. So, thought I'd just order a new slider bolt and it'd be an easy fix, but no, there are apparently two different slider bolts as per the links below; one has a cut out for the anti vibration rubber and one doesn't.
http://www.ebay.co.uk/itm/Nissan-20...arts_Vehicles_CarParts_SM&hash=item3f29db2d45
http://www.ebay.co.uk/itm/Nissan-20...arts_Vehicles_CarParts_SM&hash=item3f29db57b8
The one that is knackered on my car is the lower one (nearest the road) on the offside. I can't get at the car for a couple of days and I really need to order this, so can anyone tell me which one I need?
Secondly, the accelerator peddle is very stiff. After buying it I adjusted the cable to take the slack out of it, but it is still stiff. Is this a common fault? Easy remedy or is a new cable required?
Many thanks in advance
