should as well cos this had taken me few hours out of my busy day to measure, check, assess, design and illustrate a simple idea to someone
k, assessment.
here's the mani
the gasket illustrates where the engine studs are with the manifold upside down
the lower studs here will be impossible to get a socket to cos of the pipe.
using a spanner here, I align the closed end to the stud hole
it clears the manifold laterally
but cos the pipe is so close, you won't be able to fit it over the nut
can prob use an open end spanner but only few degrees at a time
nut will sit like this far
for the upper nut, the nut and spanner will foul abit of the corner so this will have to be grinded down
so option A, welding the stock manifold upside down onto the adapter plate permanently and then fastening this assembly onto the engine head will not work cos you won't be able to get the spanner to the nut easily.
the better option B, is to fasten the adapter plate to the block first
and then fasten the mani to that plate via relocated studs on the plate that matches the upside down mani
new studs for upside down mani added to the plate
cutaway arrangement
