JJ 1.0l
Hello all, i am afraid this is going to be a long thread as i don’t know much about fitting a bigger engine. I am thinking about fitting a bigger engine in my micra but don’t want to do too much modify to the chassis (i understand some will occur but nothing too major). I would assume you could fit a 1.6litre, 1.8litre or even a 2.0litre which is pretty insane. I have a 98 pre face lift micra on a R plate.
I have a few questions which i hope you can all answer:-
1. What is the biggest engine that has actually been fitted in a micra (under the bonnet not put in the back in place of the rear seats)
2. Can you fit other nissan engines in a micra, like from a almera or primera or pulsar etc
3. What does SR20DE mean is this a special engine that you can buy for the micra or “code word” for another nissan engine.
4. Obviously with fitting a bigger engine other things will have to be changed like suspension, but will drive shafts and axels have to be changed to cope with the extra power.
5. Also anyhthing else i need to know would be brilliant.
Also to go with this thread i wanted to lower my car by about 35mm. Anyone shed some lighton this aswell.
Cheers
Jordan
p.s if this is in the wrong place please move
Cheers
Jordan
