fiargo turbo engine in micra?
does anyone know if the fiargo engine fits a micra?
was thinkin about just puttin one of these egines in and tuning it a bit, also convert it to a manual.
You do know it's K10 based, don't you?
Like any engine, it iwll fit, but it won't be straight swap in a K11.
it is a straight fit into a micra, but its a k10 micra not k11.
The figaro engine is only 75 BHP, same as a CG13. If you're talking about putting one in a K10 its worth it as its a straight fit, but in a K11, for the effort it's really not worth it.
orite cheers lads(Y). thinkin bout buyin my mates k11 off him the timming chain's makin an awfull rattle and a cant be arsed changin it. so wot engines can i get that will be a straightish swap?
CG10 and a CG13 are the only straight fit engines.
Next easiest option is the GA16. Not a straight fit but is the easiest non standard engine option.
