My gauge never really goes past just under half way... Could be cold weather, was just curious & paranoid as usual... Flushed coolant system a while back & didn't remove thermostat as recommended by Haynes but coolant was pretty clean anyway... Was just worried I'd goosed it somehow?...
Just wanted my mind put to rest thanks...
Fan is switched by a different sensor than the guage one. Their are two plugs just behind the distributor/(where the dizzy should go if you've got coil packs) un plug the 2 wire clip. Fan should come on
Then you can see if its the fan actually not working or just your imagination hahaAah, I'll give that a go!... Cheers for the insight!
