Facelift g/box into a pre facelift K11?
Apologies if this has been asked before but I cannot find a definitive answer by searching.
Searching for a 1.0l gearbox for my 1.0l '95 K11 is proving harder than I first thought. There are plenty of facelift gearboxes for sale on the web but not the one I am after.
Therefore is it possible / involved to fit a post '97 1.0l K11 gearbox to a pre facelift engine?
I am aware the gear ratios changed slightly
From the various pictures I have seen, the speedo drive is electrical and there appears to be an additional cable coming from the diff area of the box.
Any assistance / guidance greatly appreciated.
Many thanks.
Speedos can be swapped between the two, you would need the clutch, pressure plate and flywheel off the facelift model. Not sure if the shafts are the same but I'm sure someone can clear that up
Sent from my Nexus 7 using Tapatalk
