So today saw the final heat shield go in the bin, it started to rattle on the way home last night, has anyone ever replaced them after rotting through, or has it been ok to run without them?
I just used a bit of galvanized tin, but easy to make upMaybe something like that would work for me. I can see a couple bolts that could possibly work.
Just would need to find a decent bit of sheet metal to work with.
Sent from my ASUS_T00P using Micra Sports Club mobile app
Just to the head , there is plenty mounting points on the CG, I'd Imagen the cr be the same since it's based on the CG engineIs that bolted in onto the manifold also or just above.
