Exhaust fitment?
Hi guys, not sure if this has been covered before as Im new to the forum, but does anyone know if clio / kangoo exhaust will fit k12? Looks similar in photos I've seen but not sure on bends etc.. Thanks
The main thing is to make sure that the pipe that bends over the rear cross-member is present in the exhaust system you are buying. Apart from that it's just a case of joining the pipes together using a metal collar or welding. If you look at your exhaust you'll see that it bends up and over after the exhaust mid-section and muffler before entering the backbox. My advice would be to cut the exhaust as close to the backbox as possible and then fit a muffler in its place. As far as I know there are no exhaust systems similar to the K12 ...
You'll see what I'm talking about with the exhaust bending in the attached picture
Thats great, thanks for the reply and info / photo.
I suppose like you say anything can fit within reason so long as bends are right. I dont need to replace mine just yet but handy to know for when the time comes.
