Engine mounts replacement
Upon acceleration I seem to be getting a bit of judder, nothing major though the engine mounts are original and probably the problem, are these a pig to replace?
No easy to do. Jack under the engine And replace. The 2 mounts ubder the engine are a bit harder But Nothing extreme. Jack under the engine And undo the crossbar with both engine mounts on iT. Then swap the mounts als bolt back the crossbar.
Maarten ok thank for that, will look into it.
Nissan boy, Yes, I think it is leaking slightly, will have to look at that as well!
My Micra K11 is 25 years old now (been in family since 1997) and these problems are probably routine now!
