Engine Light in 1.4 K11 2000
Hi Again,
My engine light is on, what my be the reason? I have attached OBCII and below you can see the fault code and o2 sensors.
Many thanks
Serkan
OP
OP
Acoris
Thats not the code. The code should start with a P.
Most likely causes are MAF or broken Lambda
Hi,
Thank you for your answer. Code is p0420.
Can leak exhaust cause also this?
Also my second Lambda seems damaged outside but obdii shows voltage change
OP
OP
Acoris
Update:
There was a leak at exhaust. We fixed it with pasta and metal clamp.
Now the second sensor is stable. After that we have cleared the Fault by OBDII adaptor. It is gone since 2 days!
Lets see if it will come back
OP
OP
Acoris
Update:
Here is the after fix picture of sensors
