Engine hesitates, sometimes cuts out
My 97 1.L manual gbox has hesitant acceleration/jerking and sometimes cuts out usually at 20-30mph.
I was thinking it might be needing the throttle body circuit board re-soldering.
anything else worth doing like ig coil?
cheers
clean the mass air flow meter wire too with carburettor cleaner. Some recommend electrical contact cleaner.
cheers
That should do the job, give everything a clean with carbon cleaner while you're there, although there is special maf cleaner which might be worth it since it is a very thin wire and gets damaged easily
Sent from my SM-G903F using Micra Sports Club mobile app
one week after repair so far so good, maf cleaner is £10 for a small can. expensive.
I recommend everybody re-solder their board even it its working okay, you can clean the MAF with the body out, not hard job. Took 30mins.
