Electronic Ignition Distributor
hissyfizzy
I want to replace the points distributor with an electronic one. Can I simply remove the points and put in the electronic one without adding anything, haynes manual shows a really bad picture of the distributor, coil, earth then condensor is it that simple
I'm going to replace mine because the timing is all over the place currently it's 15degree advanced I believe it's supposed to be 3degrees
Does anyone have a distributor I could buy from them
