HI
i recently tried shorting the 2 pins as suggested to test for fault codes @2000rpm but mines is showing code 55 no faults (5 long flashes and 5 short flashes) now when i let the engine tick over @8-900 rpm i got other flash readings, this was like 1 long flash and a short flash then it kinda went different 2 long flashes 1 short 1...(little confused on this one). does this mean that all the sensors ie lambda sensor is working fine! there is a rich smell from exhaust fumes like strong petrol any suggestions. the reason i ask is im only getting about 30 miles per £6 of fuel (i know its a weird amount but thats what i put in for my readings) all driving is local and not motorway.
im going to double check it again should i leave the engine running for a few minutes first before i do the check again? im gonna post a link for youtube for you guys to see later.
ive read posts regarding the lambda sensor, should i take it off and clean it?
maybe im expecting too much for local driving but is 30 miles ok for £6 of fuel plus the redex im using too!
regards
regards
