Home
Forums
New posts
Search forums
Model-by-Model
K10
K10 General Discussion
K10 Micra Blogs
K10 Tuning & Mechanical
K10 Bodywork & Interior
March Superturbo (EK10) Forum
Nissan Pao (PK10) Forum
Nissan Figaro (FK10) Forum
Nissan BE-1 (BK10) Forum
K11
K11 General Discussion
K11 Micra Blogs
K11 Tuning & Mechanical
K11 Forced Induction tuning forum
K11 Bodywork & Interior
K11s in Motorsport
March Cabriolet (FHK11)
K12
K12 General Discussion
K12 Micra Blogs
K12 Tuning & Mechanical
K12 Bodywork & Interior
K13
K13 General Discussion
K13 Micra Blogs
K13 Tuning & Mechanical
K13 Bodywork & Interior
K14
K14 General Discussion
Stickers
What's new
New posts
New media
New media comments
New profile posts
Latest activity
Media
New media
New comments
Search media
Members
Registered members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
K10
K10 Micra Blogs
K11
K11 Micra Blogs
K11s in Motorsport
K12
K12 Micra Blogs
K13
K13 Micra Blogs
K14
Menu
Log in
Register
Install the app
Install
Home
ECU problems with Nissan Micra -1998 1.0 (K11)
JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Robban" data-source="post: 521881" data-attributes="member: 14048"><p>Hi Ed... or somebody else...</p><p>I have ECU problems with Nissan Micra -1998 1.0 (K11).</p><p>For the third time I have NATS problem on my Nissan Micra -1998 1.0 l.</p><p>Every time the fault codes is 141 & 142 according to the engine check light orange blinking on the dashboard.</p><p>After all fault investigations, the ignition and spark plugs are ok, but the car will not start.</p><p>The 12 V feed (12 V supply) is ok to the fuel injectors, but the ECU is setting the fuel injectors to close off fuel and there is no earth signal to the injectors.</p><p>When spraying start gas into the throttle body the engine starts for a few seconds.</p><p>There is no problem with the keys, when the ignition is turned on the red light diode on the dashboard stop flashing.</p><p> </p><p>I'm tired of towing the car to an authorized Nissan garage to reprogramming (recode) the ECU.</p><p> </p><p>Ed, are you still selling modified ECUs?</p><p>BOSCH 0261 204 243 (970708)</p><p>Made in Germany 26RT7253 76708 6922 0750</p><p> </p><p>Thanks in advance,</p><p>Robban</p></blockquote><p></p>
[QUOTE="Robban, post: 521881, member: 14048"] Hi Ed... or somebody else... I have ECU problems with Nissan Micra -1998 1.0 (K11). For the third time I have NATS problem on my Nissan Micra -1998 1.0 l. Every time the fault codes is 141 & 142 according to the engine check light orange blinking on the dashboard. After all fault investigations, the ignition and spark plugs are ok, but the car will not start. The 12 V feed (12 V supply) is ok to the fuel injectors, but the ECU is setting the fuel injectors to close off fuel and there is no earth signal to the injectors. When spraying start gas into the throttle body the engine starts for a few seconds. There is no problem with the keys, when the ignition is turned on the red light diode on the dashboard stop flashing. I'm tired of towing the car to an authorized Nissan garage to reprogramming (recode) the ECU. Ed, are you still selling modified ECUs? BOSCH 0261 204 243 (970708) Made in Germany 26RT7253 76708 6922 0750 Thanks in advance, Robban [/QUOTE]
Verification
Post reply
Home
