Drivers Wing Mirror Adjuster
A
andy1980
Hi I need help,
I have a 2000 micra and I managed to break the wing mirror adjustment knob off,
has anybody taken one of these out before?
I just thuoght I'd ask before I go at the plastic plate with a flat screw driver!
that's all you need to do, go at it with a flat blade. you will need a new complete wing mirror though to fix it. three 10mm bolts hold it in place under the plastic cover.
Yeap I was was chatting with breakers, there is no way to mess about with the adjustes. If you disconnect the control wires, you won't be able to re connect them. So It is a full mirror.
