Door window
Hi All, I have refitted the passenger side door window which had slipped out of the clips in the door mechanism. Orignally a friend from my church who only uses k11's as transport helped me put the glass back into position, but the glue he used didn't stick well and failed ( no more nails adhesive ). So I bought the same tape that was on the glass in the first place which was double sided sticky foam tape, and push the glass back on to the clips which, had not broken off as first thought. So I didn't use the sash window clips I had bought for this job. The only other thing I found useful to remove the w/winder clip was the plastic trim tools which helped me push the clip out and put it back in again.
yours Peter0003
