Door swap
Hi, new to this forum. I have a 2002 k11 which needs a new drivers door. Will the door from a 2000 car fit? Also the 2000 car door has a rubber strip on it. Are the just glued on or are they fixed on via holes in the door. also is the strip in a recess? I thank you in advance for your help in this matter. Jon
All k11 doors and body are the same (only the front end panels were different)
Also the 5doors and 3 doors arnt interchangeable
The trim is just held on by tape and can be removed ,
