A adammichael Feb 3, 2007 #1 How do i get them off i cant seem to do it as i have dropped my window panel in the door and cant get it back up
richarda Ex. Club Member Feb 3, 2007 #2 there is 2 bolts under the arm rest on the doors, undo them then and you will need to pull the door cards as they just pop on and off
Swiper Ex. Club Member Club Member Feb 4, 2007 #3 you need to remove the window winder aswell, there's a small clip you need to remove then it just pulls off. and also the interior door opener backing, that clips out. and be carefull with the clips that hold the panel on.
