done
does anyone know how to wire up after market rev counter k11e please been looking for blue black wire but its not in my wiring loom at the back of cluster
I've done it on a dizzy cg13 but not a coil pack as I think the k11e is, the wire your searching for may not be behind the cluster.
The tachometer signal wire for the Nissan taco didn't work my tachometer it needed the return from the coil, but I imagine this will be different for the couple motor. What does the tacho installation instructions say?
OP
OP
akbar
it just say wire green to rpm signal wire
On some of the coilpack ones it stops at the connector just after the ecu. Just tap into it from behind the ecu connector.
Sent from my ANE-LX1 using Tapatalk
