Hi all, after some advice if possible?
97, K11, 67k Mike's.
Last 5 years running fine. Around October dizzy failed, replaced with a secondhand one. Fine until December, misfiring etc, changed rotor arm, cap and leads. It now runs but , it sounds as though the exhaust is blowing, put your hand over the exhaust tail pipe the gases push it away and no apparent blowing in the system? Black smoke when you accelerate hard or blip the throttle. I checked the timing today with a timing light, tps disconnected, it was "off", problem easily solved I thought, nope, on loosening the dizzy locking bolts and trying to adjust it I find it is at the end of its adjustment slot? Marks should align at 5th from the left , correct? Only gets to 4th. In for MOT next week and running out if ideas?
Any pointers please?
