Does anyone know where I can buy a side light bulb connector online?
The part that the bulb plugs into and also the part that the bulb connector plugs into is really corroded.
I’m wanting to cut one off and replace mine.
I don’t want to go to a scrap yard because they all seem to be ran by con men where I live.
I know they’ll want me to buy the full light too.
I’m keeping her for 12 months and tbh I’m not that bothered not fixing it (no mot due)
If I can order one and snip mine off and reconnect it, hassle free; then I guess I will
Hi. Iwas just looking for the individual side light connector as the headlight and indicator are not fried.
Maybe I could buy one of these and clip the old one off and wide a new one in with a block
I never got round to fixing it
Well I'm sure that would be possible so long as you find one that is compatible.
Edit :-
Hopefully someone else can help you source one online I am unable to find anything else so far..
So let me get this right you are looking for this part since 29th of august 2018 of last year and no one has reply to you until now?
And you don't want to buy a full light unit just the connector cables.
When I looked up (Headlights) there are some really reasonably priced units that look to be of great condition I can understand how you may not want to replace a whole headlamp for one small part needed.
Have been actually considering visiting a auto salvage yard or breakers yard myself for replacement pair of headlamps, As well as other items for the k12.
As for me this seems to be a place I have not visited yet. (online being where I would normally search).
bulb connectors are usually standard parts like they would be for a household lamp (bayonet, small screw fitting, large screw fitting)
In cars it's H4, H7 etc
I don't know exactly which one you're trying to replace, do you have a picture? On the back of the front lamp there are two and then another thing is the headlamp beam-height adjuster motor, and I believe also the other bulb for the highbeams. I'm planning on doing mine as well because they get hot and I think they're shorting on one side, I'm just going to do both and replace them with ceramic connectors which won't melt like plastic connectors do
