difference between K11 1.0, 1.3 and 1.4 exhaust manifold
Hi, my name is Robert and I live in the Netherlands. My car is a Micra K11 1.4 from 2001. I have a problem with my exhaust manifold, It's broken.
On www.nissan4u.com I saw the following partnumbers:
My 1.4 from 2001 uses 140041F700
1.3/1.0 before 2000 uses 1400499B00 alternative: 1400499B10
If I look by 140041F700, Nissan used it also with the older 1.0. the manifold from the 1.0 is also used in the 1.3.
So can I use every manifold to fix my car?
Guy
Have you looked at having it welded? I know cast iron can be welded with nickel welding rods :).
1.0/1.3 are the same as far as i know, and 1.4 have a longer manifold because the cat in it is a bit bigger than the 1.0/1.3
Also you can use the 1.0/1.3 manifold but you would need the whole system changed over, possibly a bit of modification required
Guy
I think if you cut Frank in half (perish the thought :laugh:), he'd have Micra written through the middle of him like a stick of rock!
frank
thank you all for the answers, what if I replace the manifold and the cat? :p
you could fit the coilpack mani/cat/downpipe assembly eh (downpipe is shorter too), but the coilpack cat has a very fine/dense core, and looked pretty restrictive to me
